Prints below freezing
JMcK
 JMcK
(@jmck)
Hey, i have an idea for food storage bins in my freezer.
How do printed plastics hold up at freezing temps for extended periods? PLA? PETG? Other material choices?
I know some of the non-printed storage containers get brittle after prolonged use in the freezer....
When someone asks you if you're a god, you say, "YES!"
Postato : 18/02/2019 4:12 am
Re: Prints below freezing
Printed plastics are not airtight; doubt they'd serve well as storage dishes.
Postato : 18/02/2019 4:20 am
JMcK
 JMcK
(@jmck)
True, but that’s not what I meant.
I was thinking of making organizers/bins. Or rather corners &connectors for dividers made of cardboard or eventually lexan.
Postato : 19/02/2019 3:20 am
DaJMasta
(@dajmasta)
There are probably a few filaments that won't get too brittle at freezer temperatures - perhaps looking towards flexibles and PETG just because they start a little more flexible is a good idea.
That said, my first inkling would be nylon. Not only are there food grade variants available, but it's widely used in variable temperature industrial applications already, so getting a formulation that has been well tested and characterized in a wide temperature range shouldn't be a problem.
Postato : 19/02/2019 6:43 am
Andrew Chaee
(@andrew-chaee)
I currently have PLA parts that have been sitting in my freezer for the last 2 years - I printed an adapter to allow bins to stack. They've done just fine.
Postato : 21/02/2019 3:25 am
