Printing with FLEX issue
Skypilot65
(@skypilot65)
I am having a significant issue printing with FLEX. My print job starts and prints the first few layers (2-4) and then the extruder quits supplying material. When I stop the job and remove the filament I get what looks like the filament was wrapped around the filament gears (see picture below). I am just plain stumped as to what is going on. Any help would be greatly appreciated. Thanks.
Cheers
Kent
Respondido : 23/08/2020 6:59 pm
Loak
 Loak
(@loak)
RE: Printing with FLEX issue
I've not started to print flex yet, here is a good place to start.
MK3s Stock, PS2.3, Fusion360, Debian, Windows 10.
Respondido : 23/08/2020 7:16 pm
Peter in Katy
(@peter-in-katy)
You may want to look into other versions of the extruder.
The  filament path is not aligned in the Prusa extruder, giving extra resistance below the gears.  I updated to the BearExxa  (with a pullybox).  I print Ninjaflex without issue.
There are also Skelestruder and Bunny Science versions you can look at.
Respondido : 24/08/2020 2:12 am
Peter in Katy
(@peter-in-katy)
Another thought, since you didn't mention it.
The Bondtech gears need to be as loose as possible.  Just  tight enough to grip the filament. No tighter.
Respondido : 24/08/2020 2:27 am
1 les gusta
layden_blackwell
(@layden_blackwell)
contrary to popular belief you can print with FLEX(Ninjaflex at least), I do It all the time. I have a configuration file you can download in fact.
To import it you can open PrusaSlicer, navigate to File> import > import Config bundle. Then just chose my file, and adjust your idler to where the end of the bolt and nut are even. Good Luck!
Respondido : 27/08/2020 12:18 am
Skypilot65
(@skypilot65)
@layden-lee234
There is an access denied error in trying to access the configuration file??
Respondido : 30/08/2020 10:27 pm
