Printing with 82A FILAFLEX 500 GR?
Hi, I tried to print this file (cylinder), after some layers (approx 1cm) this happens. I used the same settings that worked with a sample of the same filament. I have updtaed the firmware of my mk3s, does this matter? Thanks!
https://drive.google.com/open?id=19KKL3AdQalv8U4filfo5It3az5M-5R36 3MF file here
Postato : 07/06/2021 6:33 pm
RE: Printing with 82A FILAFLEX 500 GR?
Slower. Slow the max speed to 15.
Postato : 11/06/2021 1:35 am
Topic starter
answered:
@dan-rogers
I will try, thanks!
Postato : 11/06/2021 10:45 am
slow the max speed to 1.5 MVS also make sure your bondtech gear tension is proper
Good Luck
Swiss_Cheese
The Filament Whisperer
Postato : 12/06/2021 1:33 am
