Printing threads
Robert
(@robert-13)
Printing threads
I'm printing tap handles for a beer cooler and threads are 3/8-16. Is there any way I can print these or do they have to be metric?
Napsal : 14/07/2022 10:10 pm
RandyM9
(@randym9)
RE: Printing threads
I’m pretty sure Fusion 360 will allow you to make threads in most standard metric and imperial diameters and thread pitches.
Napsal : 15/07/2022 4:17 am
All depends on your modeling software. I only know for sure that Fusion can do it. But I would think most modeling software can create imperial threads.
Napsal : 15/07/2022 7:45 am
Robert
(@robert-13)
Yes, I use Fusion 360. That’s not the issue. If I draw the part in inch then convert to metric it converts the threads to metric. How do I slice and print in standard or inch? Will the printer print in inch?
Napsal : 15/07/2022 3:10 pm
Off the top of my head, I can think of three approaches:
  • Design in Fusion 360 after switching to mm as default unit. You can still use imperial thread sizes.
  • Design in Fusion 360 in inches, then when Saving as mesh, set Unit type to Millimeter in the export dialog. Imperial threads should be converted properly.
  • Design in Fusion 360 in inches, save STL in inches, then load into Prusaslicer. Right click on the model and select "Convert from imperial units"
Napsal : 15/07/2022 6:28 pm
Swiss_Cheese
(@swiss_cheese)
The Filament Whisperer
Napsal : 15/07/2022 7:33 pm
Robert
(@robert-13)
Well I was playing today and what I did was switch the drawing to standard inch and then I modeled the 3/8-16 threads. Then I switched the drawing back to metric. The threads are still called out as 3/8-16. So I’m assuming the printer will print them as such.
Napsal : 15/07/2022 7:59 pm
