Printing Quad Bearing Problems.
Frank654
(@frank654)
So I have been having issues printing this:
https://www.thingiverse.com/thing:51806
All appears to work out in a good way as it prints the pontoon and the backings (which I needed to do in Prusa Slic3r since I could do 3-degree underpins in Prusa Control)
When it begins really printing the model it neglects to stick and doesn't print a round shape, here is what it resembles.
https://imgur.com/Jq3YZsR
https://imgur.com/7qS9YJF
I am printing at .10 with Prusa PLA at 215 at the hotend and a bed temp of 60
FaceTime PC
Respondido : 11/03/2021 6:05 am
The MadCadder
(@the-madcadder)
RE: Printing Quad Bearing Problems.
Check your support contact z distance. It should be the thickness of your layer height. yours is probably at a .2mm layer height. in your case set it to .1mm. Hope this helps!
-TheMadCadder
Respondido : 11/03/2021 3:40 pm
Frank654 me gusta
Honegod
(@honegod)
I get the same effect when printing a thing that has separate pieces that have to move, where there is no way to support the 'needs to move' bit because it is inside the stationary bit. no way to remove any supports so no support  equals a stringy mess until enough layers build up enough mass to finally support actual printing of that bit.
not helpful to solve the problem but might help in identifying the problem that needs solving.
Respondido : 15/03/2021 4:00 am
