Printing prusa supplied gcodes with a different filiment.
Yazzman56
(@yazzman56)
So I have tried to print a couple of the gcode files that came with my printer but the code always goes back to pla print temperatures. So ABS won't print even if I manually change the temps. Since they are gcode I can't load them in slicer and change the filament variables. Am I missing something?
Opublikowany : 14/03/2021 1:17 am
Dan Rogers
(@dan-rogers)
RE: Printing prusa supplied gcodes with a different filiment.
GCODES are usually filament type/temp and printer specific.  Get the original model and re-slice it for ABS and you can go there!
Opublikowany : 14/03/2021 2:15 am
ssill2
(@ssill2)
Agreed.
Download the bundled models here  https://www.prusa3d.com/printable-3d-models/
And reslice for your chosen filament.  I have done this with the batman model for tpu, petg, etc
Opublikowany : 14/03/2021 12:53 pm
@ssill2
I did the same.  They good models to see if you have the filament dialed in.
Opublikowany : 16/03/2021 10:00 am
