Printing Overture TPU 95 on MK3S+
Rcflyer
(@rcflyer-2)
I have been trying to print an airless ball or bouncy ball on my MK3S+ using Overture TPU 95.  The printer is in a vinyl enclosure in my garage so it doesn't get too cold during the print.  The first try didn't turn out well and I had a hard time removing the object from the plate.  The next attempt I tried spraying the plate with hairspray but the object seemed to move around on the plate (too slippery?) - see photos attached.  I specified 30% infill and gyroid shape.  I used the preset temps:  nozzle - 1st layer 240, 235 after.  Heatbed 50.  I've read in this community and online different settings but not sure what will work best.  I also read about loosening a screw - not sure where and how, or if it is even a problem in my print.  Looking for some help to get the printer dialed in with TPU.
Note:
- PLA+ prints fine on this printer
- I also have am MK4 that I could potentially use but the MK3S+ is in an enclosure in the garage to reduce odors in the house.  The MK4 is in my basement for printing PLA mostly.
- I also tried printing an airless ball with PLA+ but it broke the first time I tried to drop it.
These are the settings that are on the Overture website for TPU:
Nozzle temperature 210 - 230 °C
Build Surface material OVERTURE Build Surface, Textured PEI, Blue Tape
Build surface treatment None / Applying PVA glue to the build surface
Build plate temperature 25 - 60 °C
Cooling fan Turned on
Printing speed 20 - 40 mm/s
Retraction distance 1 - 3 mm
Retraction speed 20 - 40 mm/s
Threshold overhang angle 35 °
Thanks,
Craig
Veröffentlicht : 14/04/2025 3:16 pm
