Printing Issue with the surface
leow.k
(@leow-k)
Dear Experts,
I am facing some issue with my 3D Print which is layer based as attached, may i know how can i smooth the print surface?
Thank you.
Napsal : 28/01/2019 10:35 am
Re: Printing Issue with the surface
The previous layer is bleeding through. When doing infill, Slic3r moves the head along until it finds a hole, then comes back from the other direction. This leaves a single thicker line at that intersection. You can see them in your photo along each hole.
Slowing down the print speed can help. Especially the infill speed. It defaults to 200mm/s which is generally too fast. I'd start at 100mm/s, and move down from there, depending on many things... no strict formula to recommend (none I can recommend because I'm still fighting this myself).
If it's the "sheen" you are concerned about, that two tone effect, slowing infill can help that, too. Or even playing with the fan speed.
Napsal : 28/01/2019 10:49 am
GeorgeE
(@georgee)
Try Cura, it has an "ironing" option which goes over the top layer a second time to smooth it out.
Napsal : 28/01/2019 10:56 am
Chocki
(@chocki)
Or try pressing it into a heated cast iron sizzler so that the sand mould texture is transferred to the surface of the print.
(Do this at your own risk, as I will nor be responsible for burnt fingers!)
Napsal : 29/01/2019 10:28 pm
supermerill
(@supermerill)
I created an ironing process for slic3rPE, the pull request is currently on hold.
If you want to stay on slic3rPE and test, it you can download my fork here ( https://github.com/supermerill/Slic3r/releases ). Please report back to see if it's worth adding, (and if it's better/worst than the cura one)
Napsal : 06/02/2019 12:51 pm
