Print stopped partially through 16hr print. Need solutions
Buckeye Slicer
(@buckeye-slicer)
Need some help/suggestions. I started a 16 hr print last night. Printed about 4 hrs., then I went to bed. When I got up this morning it had stopped at one point and had some error or alarm on display, and both bed and nozzle showed off on Octoprint. Wish I had wrote it down, something about temp or heat.I am running Octoprint on my computer, so told it to resume print. Bed and nozzle heat up, and it goes to print for just maybe 2 seconds, stops and raises up off print a few mm’s, then nozzle shuts off again, but bed stays on.I have left it in the resume position, till someone can give info whether project is doomed or can continue some how.
Postato : 10/11/2021 6:37 pm
Dan Rogers
(@dan-rogers)
What does the error message say
Couple of suggestions - Looks like a MK3S build.  What does the error message say?  How the heck are you getting Octoprint to resume a print after a printer error - it doesn't support that feature.... just saying.
Postato : 13/11/2021 1:54 pm
Buckeye Slicer
(@buckeye-slicer)
RE: Print stopped partially through 16hr print. Need solutions
Not sure what the error was. Something about temp. I cleared before thinking about it. It was something where it errored, then slightly lifted up from print, then just shut down nozzle & bed. Could it may have been “Min temp”? When I looked at Octoprint, I could cancel print or resume. When I would tap “Resume “, bed and nozzle would heat up, nozzle would lower back to print, move slightly to print, stop, then lift back up again. At that point, I could cancel or resume again, and tried several times, same thing, then just canceled the print.
Postato : 13/11/2021 4:28 pm
Dan Rogers
(@dan-rogers)
Turn it off. Turn it on. Run first layer calibration.
I'd suggest disconnecting octoprint, turn the printer off.  Turn it back on after waiting a full minute (200 mississippis).  Then what happens?  Does it just do nothing?  No power?  Does it have lights on the power supply (LED under the inspection plate)?  Error messages or current symptoms that are re-producible - thats what is missing here ...  "Something happened and now it doesn't do what I want" is kind of vague.
Postato : 13/11/2021 5:37 pm
Dan Rogers
(@dan-rogers)
Oh, and yes. Your project is toast.
That goes without saying.
Postato : 13/11/2021 5:38 pm
