Print starts ok but quickly seperates
Grandpa-G
(@grandpa-g)
What would cause the printing to start seperating after a few minutes? The printing starts from bottom of image. All the tests show no problems in setup.
Opublikowany : 14/12/2022 6:00 pm
Is this a new printer or one that has been printing OK for a while?  Has it been dropped?
Your first layer Z calibration is not low enough but it looks as if it *might* be OK at the far end ...
It mght be worth running an XYZ calibration.
https://help.prusa3d.com/article/xyz-calibration-mk3-mk3s-mk3s_112351
Opublikowany : 15/12/2022 4:10 am
Grandpa-G
(@grandpa-g)
RE: Print starts ok but quickly seperates
It is not new and this problem just started a few days ago. No damage to the printer. I have been working on the Z calibration. I am also having a problem with the item not sticking to the bed, even though the bed has had all the cleaning techniques used.
Opublikowany : 15/12/2022 3:28 pm
OK.  The first layer 'Z' has to recalibrated from time to time as the nozzle wears...
and this too can be a symptom of the same.
Let us know how you get on.
Opublikowany : 15/12/2022 11:54 pm
