Print setting woes
DST
 DST
(@dst)
Print setting woes
Hello, I can’t figure out how to masks this end of layer area print smooth everytine it resets and turns around in this area. Also, I’m printing this without supports and I’m getting these lumps on exterior. What can I do to improve? .6 nozzle .15 layer height on wood/pla.
Mom, wife, career woman, tinkerer.
Napsal : 15/08/2021 5:19 am
surface defects
could you please add some pictures showing the problem?
Napsal : 15/08/2021 8:15 am
DST
 DST
(@dst)
Pictures attached.
Hi Joann, Taht would have helped.
I think I may have had my retractions settings in and not needed in this model?
Napsal : 15/08/2021 8:23 am
Or even better, save your project as a 3mf file from Prusaslicer's File menu, then ZIP it and upload it here. This way we have your model AND all your settings.
Napsal : 15/08/2021 10:53 am
Possibly a solid infill issue
Take a look at this thread. I suspect the problem is caused by the way PrusaSlicer generates solid infill inside sloped walls. It can easily lead to over-extrusion.
Napsal : 15/08/2021 7:44 pm
1 lidem se líbí
Swiss_Cheese
(@swiss_cheese)
@dst
Aside from possible Infill issues generated by Prusa Slicer, you may also be trying to print your layers to low relative to your nozzle diameter for wood PLA.
Regards
Swiss_Cheese
The Filament Whisperer
Napsal : 16/08/2021 6:08 am
1 lidem se líbí
I didn't notice the OP's mentioning of wood until @swiss_cheese pointed it out. These artifacts are exactly what I've noticed with some brands of wood PLA. I found them to be more pronounced the higher the percentage of wood in the filament.  Usually I don't bother printing temp towers anymore with today's quality filaments but I always do it for wood, which seems more finicky, to find the lowest temperature I can print it at. I've printed some gorgeous stuff in wood but lumps particularly at the z-seam seems almost inevitable, but they usually come off easily with a bit of polishing.
Napsal : 16/08/2021 10:19 am
1 lidem se líbí
