Print keeps failing at same hight
Kimberley Attwell
(@kimberley-attwell)
I am hoping someone can help work out what is causing this print to fail at the same hight every time.   I have tried several things to try and get it to finish the print this includes.
Prusa MK3s filament is PLA
Replaced nozzle
Replaced hot end
Replaced bed
Full calibration
Live Z tuning
Changed filament
Re sliced the print in case there was somthing wrong with the gcode
all layers below where it failed look really good.
Postato : 24/12/2022 2:45 am
RandyM9
(@randym9)
Btw, this post belongs in the ‘First prints troubleshooting’ section, not general discussion.
What is your experience level with 3D printing in general and with the MK3S in particular?
Your pic appears typical of trying to print bridges or overhangs with no supports. The layers are printing in mid-air so there’s nothing below to adhere to. But that’s just a guess.
Please save your file as a .3mf project file, zip compress it, and upload it here so other users can see your model and all the settings which helps us to offer better suggestions. It must be zipped as the forums don’t accept many file types, including.3mf.
Cheers
Questo post è stato modificato 3 years fa da RandyM9
Postato : 24/12/2022 5:23 am
