Print Gyroid
Hello,
I have a gyroid lattice of varying unit cells which I generated using python. Now, I wish to print it using Prusa but I get the error as the printer is empty. check your printer settings. Please suggest the settings to print this type of object.
The printer's nozzle diameter is 0.4mm
Napsal : 16/11/2022 6:48 pm
RE: Print Gyroid
Please post a 3mf project file, which contains the STL and all your settings. That way you're more likely to get answers that are sound and not just based on guesses. The file has to be zip-compressed for upload, or the forum software won't accept it. If I had to guess, you may have areas too thin to print with a 0.4mm nozzle.
Napsal : 16/11/2022 8:40 pm
