Print continued but without extruding and without being clogged
After printing ~12.51 mm this print stopped extruding. The heater elemet turned off but it continued to go through the motions. There was no clicking and when I checked on it 6 hours later I canceled the print. I instructed the printer to unloaded the filament. It then went throught the preheating processes and the then the filament was removed without issue. This has never happed before. Usually when this happens the fillament is clogged and broken and the extruder is clicking.
Link to gcode https://drive.google.com/file/d/161eVEmHyfuggcSMIG8MCUNS982myKRmZ/view?usp=sharing
Opublikowany : 09/07/2023 12:45 pm
