Poor PLA adesion on Powder Coated PEI
NathanK
(@nathank)
I have had my new Prusa I3 MK3S+ for a couple of days now and have spent several hours fine tuning everything. The first layer is perfect, PETG prints quite well and all seems to be working very nicely. But I am having fairly poor adhesion. Prints, especially PLA don't seem to want to stick to the surface, I have wiped down with IPA before every print and I am printing at 220 with 65 on the bed and that helps more often, but it's still a dice roll on whether prints will stay down the whole time. I know the smooth PEI bed works better with pla but I rather enjoy the texture the powder coated gives and I don't want to buy another bed just for PLA. What can I do to get really good adhesion with the powder coated PEI? Thanks in advance.
Publié : 28/11/2020 7:52 pm
RE: Poor PLA adesion on Powder Coated PEI
Posted by: @nathank
It is normal for PLA to adhere better to the laminated PEI printing plate and PETG to be printed on the textured one.
https://forum.prusa3d.com/forum/english-forum-awesome-prints-hall-of-fame/pla-on-textured/
As an alternative Prusa offers a satin printing plate, with which both materials (PLA and PETG) should print well.
https://shop.prusa3d.com/de/i3-zubehoer-mk3s-mk25s/1393-oboustranny-ocelovy-pruzny-tiskovy-plat-se-satenovym-praskovanym-pei-tiskovym-povrchem-pro-original-prusa-i3-mk3s-a-mk25s.html
Publié : 28/11/2020 9:30 pm
Peter M
(@peter-m)
Clean bed with dish soap, is a lot better.
Do not touch the bed with your fingers, then sticking will get bad.
First layer calibration needs to be 100%, on powder coated bed you need to go a little lower, to get good sticking.
If you use alcohol, use a lot of alcohol and not only a little, dish soap is better.
Petg should work with powder coated bed.
PLA, always wash with dish soap, higher bed temp is better(10), first layer nozzle temp also higher, use a big brim, and if needed use glue stick.
I washed mine powder coated bed with dish soap(3 times with hot water), and use a little the green scratch side(your own risk) , and pla is still difficult.
Publié : 29/11/2020 6:38 am
