PETG print problems
I'm using atomic PETG filament with the stock prusa slicer settings. I'm having difficulty printing this gear without getting holes through out the print. I've adjusted the temp and slowed the print to 50% and I get the same result. So, maybe it's an underextrusion problem? But, the 20mm x 20mm x 20mm cube used to test extrusion comes out beautifully. Thank you for your thoughts!
Napsal : 09/08/2019 12:51 am
