Odd missing bits?
Dusk
 Dusk
(@dusk)
Odd missing bits?
I've been through all the troubleshooting I can find and still cant seem to find the problem cause my prints to do this. Everything seems fine and it usually will do a significant portion before it starts. Anyone have ideas? I've checked the belts, tried opening a new spool of filament thinking maybe it was that, check tension on the extruder and again, have no ideas.Missed bits
Best Answer by --:
Extruder tension screw needs to be rather tight on the MK3S.  You might try adjusting it on the heavier side before chasing other less likely causes.
Respondido : 29/09/2019 7:04 pm
Miembro
RE: Odd missing bits?
Under extrusion?
Respondido : 29/09/2019 7:30 pm
Respondido : 29/09/2019 7:34 pm
Dusk
 Dusk
(@dusk)
I'll tighten it up some more then, but I'm still on the base mk3, I have yet to print out the mk3s upgrades because I've been having this issue.
Respondido : 29/09/2019 7:38 pm
Miembro
Posted by: @tim-m30
This one thing that got me.  It is much tighter than the MK3.
Dusk
 Dusk
(@dusk)
Tightened it about a full rotation, and it's kinda aggravating that it seems to be infinitely better. I thought I had that down to where it needed to be, thanks a bunch everyone!
Respondido : 29/09/2019 8:59 pm
On a MK3, screw tips flush with the extruder door is about right.  If I get twisting in the filament leading from the spool I'll back one screw off a bit, if the odd twist/click keeps on (different sound than a jam and you'll get filament trying to unravel off the side of the spool), I retighten that screw and back off the other one.  On the other hand, flexible filament requires a very light touch.  The term touchy adjustment comes to mind.
Respondido : 30/09/2019 3:42 am
