Odd missing bits?
I've been through all the troubleshooting I can find and still cant seem to find the problem cause my prints to do this. Everything seems fine and it usually will do a significant portion before it starts. Anyone have ideas? I've checked the belts, tried opening a new spool of filament thinking maybe it was that, check tension on the extruder and again, have no ideas.
Best Answer by --:
Extruder tension screw needs to be rather tight on the MK3S. You might try adjusting it on the heavier side before chasing other less likely causes.
RE: Odd missing bits?
I'll tighten it up some more then, but I'm still on the base mk3, I have yet to print out the mk3s upgrades because I've been having this issue.
This one thing that got me. It is much tighter than the MK3.
Tightened it about a full rotation, and it's kinda aggravating that it seems to be infinitely better. I thought I had that down to where it needed to be, thanks a bunch everyone!
On a MK3, screw tips flush with the extruder door is about right. If I get twisting in the filament leading from the spool I'll back one screw off a bit, if the odd twist/click keeps on (different sound than a jam and you'll get filament trying to unravel off the side of the spool), I retighten that screw and back off the other one. On the other hand, flexible filament requires a very light touch. The term touchy adjustment comes to mind.
