Nut insertion
Hy all 🙂
Today, i'm trying to enclosed a small nut in a 3D printed part.
The "pause" fonction on prusa slicer work perfectly but during pause, petg continue to flow down from the extruder and when I resume the print, I'm noticing a small lack in the first resumed layer :
I'm affraid that this will weaken my print.
Do you know how to correctly resume the print ?
Thanks by advance !
RE: Nut insertion
Hy all 🙂
Thanks by advance !
Try adding a color change instead of pause, insert nut, unload and load same filament.
That way printer will push out new fresh filament before it starts printing again
I prefer to do this instead of using pause
Prusa i3 MK3S+ FW 3.11.0 (kit dec -20), PrusaSlicer 2.6.1+win64, Fusion 360, Windows 10
RE: Nut insertion
Ok !
Thanks for your feedback !
I will try this.
I was wondering about expend the skirt upond the pause layer or had a simple object that would suffer the lack of material istead of my main part.
But your option seem's far better to me.
Thanks again !
RE: Nut insertion
Can't you clear the excess material from the nozzle with pliers (or if you're a real man just use your fingers)
