Not Exactly Layer Shifting Issues / Misalignment
I am getting misalignment consistently around the same layer lines. I checked my STL and moved the print around the bed, but the issue does not go away.
I just got this MKS3+ about 3 weeks ago and have had successful prints except this model.
It seems to be happening after the infill gets a top perimeter and the printer continues to print above it.
PETG/230C/77C/Satin/Textured
I hesitate to call it a layer shift, because the filament expands out on all four sides of the model.
Welcome to "The Bulge"!
This is a well-known phenomenon, with more than 20 pages of discussion in this forum.
TL;DR: Many suggestions, no universally applicable solution.
To quote @bobstro:
Happily, this was described as a “buldge” in an early post and that misspelling has made the problem very easy to search for. There are several threads you might want to look through:
Thread three - Mitigate wall bulge.
RE: Not Exactly Layer Shifting Issues / Misalignment
Yes, appears that there is no real solution. But at least you got me the correct term to search for.
Thank you!
