no extrusion at 115 °c
Julien Pierre
(@julien-pierre)
Hello,
I would like to extrude polymer with low meting points, I would like to extrude at 115 °c. My I3 MK3 move but doesn't extrude. i thing security parameters don't accept extrusion at 115 °C.
Does someone have a solution ?
Opublikowany : 19/10/2018 4:16 pm
Peter L
(@peter-l)
Re: no extrusion at 115 °c
Hello,
You may need to recompile the firmware with a different setting and reflash it.
Opublikowany : 19/10/2018 5:46 pm
You can try overriding the default (190C I believe) by inserting the following in your filament or printer start g-code:
M302 Sxxx ; Sets the minimum temp to xxxC
I don't know just how low you can go with it though.
Opublikowany : 19/10/2018 6:30 pm
Julien Pierre
(@julien-pierre)
Thank you, my first test are fine.
Opublikowany : 22/10/2018 9:47 am
