no extrusion at 115 °c
Hello,
I would like to extrude polymer with low meting points, I would like to extrude at 115 °c. My I3 MK3 move but doesn't extrude. i thing security parameters don't accept extrusion at 115 °C.
Does someone have a solution ?
Re: no extrusion at 115 °c
Hello,
You may need to recompile the firmware with a different setting and reflash it.
You can try overriding the default (190C I believe) by inserting the following in your filament or printer start g-code:
M302 Sxxx ; Sets the minimum temp to xxxC
I don't know just how low you can go with it though.
Thank you, my first test are fine.
