Newbie needing some assistance on a print
print_n00b
(@print_n00b)
Hello! Came across a file to print a finger chopper magic trick that my kid saw at a party. Wanted to print it but I'm guessing there are other steps involved that I'm not familiar with.
The downloaded file was in a .step extension, which prusa slicer was able to open, however when I sliced and printed, it came out as a solid piece and doesn't work as it should.
How do I tell if this was meant to be printed as a whole, or if I need to print the pieces separate and assemble? If printing separate, how do I go about separating the pieces to print?  Thanks!
File in question:
https://thangs.com/designer/eros.nicolau/3d-model/Finger%20Chopper-42085
Dieses Thema wurde geändert Vor 3 years von print_n00b
Veröffentlicht : 12/12/2022 9:30 pm
Hello
(@hello)
RE: Newbie needing some assistance on a print
Can you please put photo of the failed print
Veröffentlicht : 13/12/2022 6:50 pm
That looks like five parts to print and assemble...
You will need to rotate some of them to get clean prints.
Veröffentlicht : 13/12/2022 7:17 pm
print_n00b
(@print_n00b)
Here's how it came out, front and back. Top is suppose to be removable.
Veröffentlicht : 14/12/2022 3:47 am
print_n00b
(@print_n00b)
Posted by: @diem
I was suspecting it might need to be printed in parts, however no idea how to do that.  Any suggestions would be appreciated?
Diese r Beitrag wurde geändert Vor 3 years von print_n00b
I'm not going to create an account to download it, so this is generic:
Import the file.  Select the assembly. Click the 'Split to Objects' icon (at top).  Click on free space to deselect.  Click on the 'Arrange' icon (also at top).
You should now see all the parts.  They are probably not oriented well for printing so you may need to rotate them.
Veröffentlicht : 15/12/2022 3:16 am
Hello
(@hello)
Hi there wont let me add file for some reason if you tell me what printer you have i can make gcode for you if needed
Veröffentlicht : 15/12/2022 3:19 am
Zip before posting.
Veröffentlicht : 15/12/2022 3:23 am
print_n00b
(@print_n00b)
Posted by: @hello
I'm using the mk3s with PLA and that would be awesome.  I would also appreciate if you could let me know what software and how you ended up doing this with so I can learn to do it for myself as well.  Are the steps similar to those outlined above by Diem?
Posted by: @diem
Thank you. Will try this when I get home.
Veröffentlicht : 15/12/2022 3:29 am
Hello
(@hello)
i am just making gcode now
Veröffentlicht : 15/12/2022 3:32 am
Hello
(@hello)
thank you for the advice of zipping
Veröffentlicht : 15/12/2022 3:33 am
Hello
(@hello)
just added file you can do the way described above or you can use somthing like a program eg fusion 360 many out there but i would just recamend the way above
Veröffentlicht : 15/12/2022 3:36 am
Hello
(@hello)
thank you for advice of ziping
print_n00b
(@print_n00b)
Thank you @Hello for uploading the files and thank you @Diem for the instructions.  I can't believe how simple that was.  Will be attempting to print now.
Veröffentlicht : 15/12/2022 5:41 am
Hello
(@hello)
cool please let us know how it goes i configured g code exactly like you said your printer was configured
Veröffentlicht : 15/12/2022 5:57 am
Robin
(@robin)
@print_n00b Be careful what you feed your printer with, it is generally not a good idea to print g-code you downloaded from somewhere (even from this forum). 3D-printers are machines capable of self destructing.
@hello Better post the slicer project, so the OP can see the settings and slice the model.
Veröffentlicht : 15/12/2022 1:40 pm
print_n00b
(@print_n00b)
@robin thank you. I haven't even considered malicious gcode could potentially ruin your printer.  Will definitely be more cautious in the future.
@hello the print came out great and best of all, works!  My son was so amazed, again.
Veröffentlicht : 15/12/2022 3:35 pm
Hello
(@hello)
I did put stl of all split parts Incase you wanted to do it
Veröffentlicht : 15/12/2022 5:35 pm
Hello
(@hello)
Happy to help
Veröffentlicht : 15/12/2022 5:41 pm
