Need help have layer height gaps on my print.
diicasses
(@diicasses)
You can notice it on the Purple vase which is using PLA. I recalibrated a lot with the red vase using PETG. So its barely noticeable.
If anyone has any idea of what might be causing this. I was getting oozing with the PETG so I adjusted the retraction length and speed and it fixed the problem.
Posted : 05/01/2023 9:12 pm
Reset to defaults and dry the filament.
Better?
Posted : 06/01/2023 12:34 am
diicasses
(@diicasses)
RE: Need help have layer height gaps on my print.
I dehdrayed filaments, also I am using two different ones here. I printed with new settings/calibration and its not as obvious as the purple one so its pretty passable or acceptable. Maybe the I need to squash the layers some more.
Posted by: @diem
Better?
Posted : 06/01/2023 2:28 am
If you are certain your filament remains absolutely dry, try the default 20mm SPEED setting with two perimeters and 20% cubic fill.
Posted : 06/01/2023 4:28 am
