My first ABS - R3 Extruder upgrade
Paul Harker
(@paul-harker)
Today I printed my first ABS. I printed several test ducts Using Matterhackers ABS and generic ABS from Slic3r at several temperatures. (Matterhackers says 230 +/- 10) The best result were at 220, however there was still excessive sag in the horizontal bridges. So I activated fan cooling at 30% while printing bridges, and upped print temp to 225 and got a nice duct.
Using this config I printed the front and back Extruder parts
Overall they are nice except for a couple bridged areas:
Any advice as to how to improve these prints much appreciated.
Edited to reduce size of photos
Postato : 18/07/2018 9:16 pm
Martin Wolfe
(@martin-wolfe)
Re: My first ABS - R3 Extruder upgrade
You are on are on the correct lines. Just try adjusting the fan for bridging by 5%. Also it is only the nozzle that needs to be ABS or an other high temperature filament. PETG is the recommended filament for everything else.
Regards,
Martin
Martin Wolfe
Postato : 18/07/2018 9:52 pm
Paul Harker
(@paul-harker)
Martin, thank you for the guidance!
I realize that PETG can be used for the other parts, but I don't have any black PETG, and I thought this would be a good exercise in dialing in and troubleshooting ABS. I'll probably order some black PETG if I'm not happy with my end results after an iteration or two.
Postato : 19/07/2018 12:21 am
zerg
 zerg
(@zerg-2)
Did you get anywhere with printing this? The fan shroud is my 1st ABS print as well.
Edit: I ended up with good results after tightening the idler gears by 1/2 a turn, using a bed temperature of 110, and an extruder temperature of 225, with a bridge fan speed of 30%. I used the 0.20 stock profile.
Postato : 21/07/2018 10:51 pm
