Multi-Colored Print keeps extruding a blob on the whipe tower
So im using a Mk3S without the MMU. I want to print a model that consists of 4 parts, each being a different color. Problem is, when I manually change the filament, the printer makes a blob on the whipe tower, which cools down and the nozzle crashes into it, making him loose his positon.
Any idea as to why that is and what i can do against that?
Postato : 30/03/2024 6:46 pm
Topic starter
answered:
RE: Multi-Colored Print keeps extruding a blob on the whipe tower
Got it working after all.
Under PrinterSettings/SingleExtruderMMsetup set Extra Loading Distance to -85.
Should make the blob small enough so that it doesn't cause problems anymore.
Postato : 30/03/2024 10:39 pm
