More Stringing with heigher extrusion width?
I want to optimize my print with PETG for overhanging models. Therefore I reduced mit layer height and increased the extrusion width.
Layer height = 0.15 -> 0.1
Extrusion Width = 0.45 -> 0.5
Before I reached ~ 65-70° and now ~ 70° but unfortunately with more stringing.
Rectration: 2.5mm
Retraction speed: 50mm/s
Rectract amount before wipe (Coasting): 50%
Filament Temp: 200°C (210-230° recommended)
Extrusion Multiplier: 0.95
Cooling 80%
Speed: 45mm/s
Travel: 180mm/s
1.) Does Prusa Slicer automatically adjust the Flow Rate if changing the Extrusion Width, Layer height or Speed?
2.) Does a heigher Extrusion Width means more pressure on the deeper layer and more contact to the filament and so more stringing?
Thanks...
RE: More Stringing with heigher extrusion width?
Interested and subscribed to see if you get an answer.
As for 1) this may be the info you are looking for https://manual.slic3r.org/advanced/flow-math or in short: yes
Thanks and what do you mean to 2.)?
