More battles with stringing - Path of least retraction?
Hello hello!
Okay so today I want to print a beautiful sacred geometry mesh. My design is perfect, of course! (screenshot attached)
BUT - When the slicer organizes the print, my extruder bounces around for the tiniest fragments here and there instead of calculating a single line with as little lifting from the surface as possible.
When I make a mesh using the standard infills, like triangles, the path the extruder takes is wonderful. Straight lines, continuous. Clean.
Is there a way I can ask PrusaSlicer to do the same with my sacred geometry mesh?
Thanks, Andrew
PS: Extra Credit for the truly bold - how do I make my sacred geometry one of the infill patterns!
Opublikowany : 18/03/2022 11:37 pm
RE: More battles with stringing - Path of least retraction?
For that you will have to play around with your extrusion width settings.
Opublikowany : 19/03/2022 10:12 am
