[Rozwiązany] Looped overhang issues
bryang1
(@bryang1)
So I'm printing birdhouse as a gift and I noticed this looped overhang happening in a couple spot all around the same level of the print. I'm wondering if this is geometry issue as the ledge dips down in these spots. If so what could I do to fix it?
I'm using a MK3S+ with prusament PLA, .4 nozzle printing at .2 layer height. Nozzle temp is 215
Thanks
Best Answer by Thomas:
Yes you need some supports there. I would use use the 'paint on supports' function in Prusa Slicer. Very useful if you don't need/want supports everywhere but only on that particular section and sections like it.
Opublikowany : 27/01/2022 4:35 am
RE: Looped overhang issues
Well the obvious answer is to add some snug supports to those areas.
Opublikowany : 27/01/2022 6:00 am
1 ludzie polubili
Thomas
(@thomas-14)
Opublikowany : 28/01/2022 12:31 am
1 ludzie polubili
