Lightbox with MMU
Sven
 Sven
(@sven)
Lightbox with MMU
Hi everybody
I would print a Lightbox with my MMU bit the Lines are not close enough to close the surface complete.
Unfortunal an import of 3MF files ar not possible.
Error (Invalid 3MF format) while parsing '3D/3dmodel.model' at line 20
No matter which file i will take.
So i have to put manualy the settings to my slicer.
Flow rate, Speed maybe temp needs to figured out.
I hope of some Setting from our community to safe time and to much failprints..
Thanks in forward
Respondido : 26/12/2023 8:00 am
Robin
(@robin)
RE: Lightbox with MMU
You might want to post the file you are trying to import/print and tell us which software you are using.
If you are hoping for settings, you need to be more specific about your hardware (printer model, nozzle size, filament...), generally the deafault settings in slicer are pretty good, given you select the correct hardware.
Respondido : 26/12/2023 5:46 pm
Sven
 Sven
(@sven)
I use the standard Prusa slicer.
0,4 Nozzle
Prusa Pla
ON the photo you can see that the lines are not merging.
it looks not really nice.
so I guess i need to change settings for flow rate, temp and speed.
off course i can figured it out with plenty of test but I hope that the community have allready settled out a profile to fix that issue
best regards
Esta publicación ha sido modificada el hace 2 years por Sven
Respondido : 29/12/2023 9:38 am
Robin
(@robin)
Sorry, I do not understand where your problem is, you are using Prusa Slicer, a Prusa MK3/MMU2 with standard 0.4mm nozzle and Prusa PLA.
Why don’t you just use the default profiles for that setup in Prusa Slicer?  It works perfectly. Do you have the default profiles installed in Prusa Slicer?
Respondido : 29/12/2023 1:58 pm
