layer height/nozzle size effect on object strength
Ray of Hope
(@ray-of-hope)
I was searching through the PrusaSlicer settings looking for ways to effect print speed.  One idea was to increase the layer height.  The default is 0.15mm and setting the height to 0.25mm cut several hours off the estimated print time.  Is there a way to predict the effect on the strength of the object?   I suppose the nozzle size might need to change, also.  Is there wisdom here on the how layer height/nozzle size relationship?  I'll be testing these changes, but wondered if it was a known function.
Veröffentlicht : 29/08/2022 5:44 pm
ARU
 ARU
(@aru)
RE: layer height/nozzle size effect on object strength
Stefan from cnckitchen made many videos on YouTube about these settings and their effect or not on the piece strength.
Regards
Veröffentlicht : 29/08/2022 5:59 pm
Ray of Hope
(@ray-of-hope)
thanks for the hint:
Veröffentlicht : 29/08/2022 6:09 pm
No need to change nozzle sizes. As a rule of thumb nozzles can print layer heights up to 80% of their diameter (so for a 0.4 mm nozzles that's layer heights up to 0.32 mm) no problem. Prusa also published a quite decent blog post on using different nozzles and impact on time and quality a few years back: https://blog.prusa3d.com/everything-about-nozzles-with-a-different-diameter_8344/
Veröffentlicht : 29/08/2022 10:04 pm
