Keep having to remove reinsert the filament
NealC
(@nealc)
Doing a large print job and all of the sudden I get the beeping. Remove filament. Insert filament. 5 minutes later, beeping, repeat the process. I finally turned off the filament sensor and it's printing as expected. I'm not concerned with running out of filament on the full spool.
What is causing this problem?
I love my i3 MK3 but it sure seems less reliable than my other printer, a FlashForge Creator Pro. All these gee whiz things but they are causing problems such as in my other threads. My FlashAir SD card often has to be removed/reinserted. I had print fan issues when the wire internally broke. I absolutely love this printer but I can't seem to step away from it and trust a print can complete without some interaction.
By the way, prusament is amazing! What a difference! I wish it was easier to get and hear it may be such as on Amazon but it's awesome stuff!
Neal C
Richmond, VA
Postato : 05/01/2019 12:35 am
Robin
(@robin-4)
Re: Keep having to remove reinsert the filament
Filament sensor is either not liking your filament or its dirty. I just leave mine switched off
Postato : 05/01/2019 2:44 am
alternatively, insert a proxy bearing between the filament and the sensor, using this update
https://www.thingiverse.com/thing:3223513
Postato : 05/01/2019 11:40 am
ludodg
(@ludodg)
Having the same issues 🙁
Postato : 26/01/2019 11:13 am
Robin
(@robin-4)
In settings menu on the printer switch off the sensor as a temp fix. mine is just turned off all the time now.
Postato : 26/01/2019 11:35 am
ludodg
(@ludodg)
I also used this "fix" .. but this is more of a work-around and not a real solution.
Postato : 26/01/2019 11:43 am
Robin
(@robin-4)
Use the link in Joan's comment for a full fix
Postato : 26/01/2019 12:42 pm
Mustrum Ridcully
(@mustrum-ridcully-2)
a squirt from a can of dust-off caned presser blower seems to take care of this for several days give the bond tech an air blast from both sides as well
Postato : 26/01/2019 6:43 pm
NealC
(@nealc)
Yes, that did work when I did this about two weeks ago, good suggestion. As I purchased my unit assembled a lot of this is learning and good learning on reverse engineering/assembling it. So I learned of the parts involved in my investigation and it was quite dirty for whatever reason and a good blow out did the trick.
Neal C
Richmond, VA
Postato : 27/01/2019 3:29 pm
