Jamming on 6hr Plus Prints
nzxela
(@nzxela)
4 hour prints look perfect but at more than about 6 hours the PLA filament jams in the PTFE tube.  I have been printing for years and small prints are fine.
When I take the hot end apart I find the filament has jammed in the PTFE tube.   I was in the room the last time the issue happened. At about 7 hours I heard clicking from the filament gears. I tried increasing the tension on the gears which improved it a bit. Then the clicking started again. This time I increased the temperature from 210 to 220 (PLA) and the clicking stopped again and then finally the filament jammed and could not be moved.
After the first time this happened I stripped down the head, heat break etc according to the online instructions, ran the calibration wizard and it ran fine perfectly for small prints before jamming on a long one.
Any ideas appreciated. Thanks Alex
Best Answer by Eef:
That might be "heat-creep". See https://help.prusa3d.com/article/extrusion-stopped-mid-print-heat-creep_1948 for explanation.
When the printer is in a hot room/enclosure this happens most of the time first when PLA printing.
Postato : 09/06/2024 7:35 am
nzxela
(@nzxela)
RE: Jamming on 6hr Plus Prints
FYI. MK3S+
Postato : 09/06/2024 10:20 am
Eef
 Eef
(@eef)
Postato : 09/06/2024 7:31 pm
1 persone hanno apprezzato
