Issues with in-fill
Cam Alberghini
(@cam-alberghini)
Issues with in-fill
I am trying to print this piece for production, and on the right side of the part you can see a small patch where the infill is less consistent. What tips do people have to fix this. My first thoughts were a smaller nozzle and maybe something when slicing/print settings. Any help is greatly appreciated!! (Printed with Jet Black PRUSA PETG, and the 0.4mm nozzle that comes with the printer)
Napsal : 25/07/2023 5:03 pm
RE: Issues with in-fill
Save the model as a project file. Then zip compress the project file.and finally attach the project file to your next post.
Then we can look at it and make informed suggestions
Regards Joan
Napsal : 25/07/2023 5:31 pm
Plenty of ways to possibly address it but without seeing the model and settings in the form of the 3mf file as Joan suggested, it would all be wild guesses. If you don't want to share it, one parameter I would look at is adjusting extrusion width.
Napsal : 25/07/2023 6:16 pm
Cam Alberghini
(@cam-alberghini)
Clamp_neck_v2 - long - Metric
Sorry that took me a sec had to do some other work quick. The reason we have so many perimeters is that seemed to increase printed part strength a lot!
Thank y'all for the quick responses!
Napsal : 25/07/2023 6:36 pm
here's one option.
Clamp_neck_v2 - long - Metric JT
Napsal : 25/07/2023 8:03 pm
Cam Alberghini
(@cam-alberghini)
Thank you so much! We are gonna do a test run now!
Napsal : 25/07/2023 8:19 pm
Good solution. I don't think this will be any worse in parts strength.
Napsal : 25/07/2023 8:26 pm
Best wishes.
Joan
Napsal : 25/07/2023 8:32 pm
