Is Prusament Mystic Brown clogging the nozzle at low speeds?
Pagina 1 / 3
Spacemarine
(@spacemarine)
Does Prusament Mystic Brown clog the nozzle at low extrusion speeds?
I noticed that I can print fine at the standard 0.2, 0.15 and 0.1 mm layer hight with the Prusament PLA setting. (Slic3r 1.42-alpha 3 and 3.5.1 Firmware on I3 MK3 with 0.4 mm nozzle) But as soon as I go to 0.05 mm, the print fails after the first layer. (Even with the included Treefrog 50 µm on the supplied SD card) Sometimes it fails directly after the first layer, sometimes it takes a while. But it fails always!
The failure results in massive underextrusion, which is also audible as the extruder clicks and vibrates the infeeding filament because the steppermotor skips.
To investigate I extruded a lot of filament with different extrusion speeds. I did:
G83 (set relative coordinates)
G1 E10 F100 (extrude 10 mm at 100 mm/min)
I can run this as often as I want, but if I do:
G1 E10 F5 (extrude 10 mm at 5 mm/min)
The nozzle will sometimes start to clog and the extruder starts to click. Even if is does not click during the execution of the command, every start of the command brings a click if the previous extrusion was very slow. I suspect that the glittering effect particles will behave weird at low extrusion speeds.
Can anyone confirm this problem? I don't have othe PLA filament at hand, so I can't compare. This thread indicates that the problem also exists with Prusa Silver PLA: https://shop.prusa3d.com/forum/others-archive--f66/help-with-0-05-mm-layer-height-t15052.html
Can anyone with a Prusa or Prusament with effect particles try this? Just use the Treefrog 50 µm on the included SD card.
Postato : 16/01/2019 12:33 am
Butterworth Design
(@butterworth-design)
Re: Is Prusament Mystic Brown clogging the nozzle at low speeds?
I can confirm with Prusament Vanilla White PLA. Low speed appears to be the consistent factor. I had two Benchy boats fail at exactly the same point with extruder jams (PLA at wider diameter in heatbreak beneath PTFE tube). The prints both failed when the print speed dropped to 15mm/s at 0.15mm layer heights, at the boat cabin window area where there are frequent retractions.
After the first failure, I was able to remove the filament with a typical "unload filament" and pull. I followed with a cold pull with some cleaning filament - the result was a pristine and perfectly clean and complete impression of the hotend (including nozzle opening).
The second failure was worse, and I was unable to separate the PLA from my PTFE tube (I'm replacing it tonight).
I had made no changes to the printer and had printed four different beautiful benchies in various other PLAs (including three benchies with the Prusa Silver PLA that shipped with my printer, AmazonBasics Premium, Matterhackers Build series, etc) recently. I used the Prusa PLA profile for the prior prints, and the Prusament PLA profile with these failed prints, but there doesn't seem to be any significant difference between the two profiles. Printer profile was also set to the default.
To me, it seems that Prusament is more susceptible to heat creep through the filament itself than other materials and filaments I have used, and Prusa's Slic3r PE "Prusament PLA" profile (and possibly the default printer profile as well) doesn't take this into account. I would be very concerned with any print at this point with low extrusion rates in Prusament PLA.
MyMiniFactory (Functional Parts and Mods): https://www.myminifactory.com/users/butterworthdesign
Thingiverse (Fun Designs and Remixes): https://www.thingiverse.com/uscbutterworth/designs
Twitter: @USCbutterworth https://twitter.com/USCbutterworth
Postato : 16/01/2019 10:05 pm
Spacemarine
(@spacemarine)
Today I tried to print a large object with very fine details with Prusament Mystic Brown at 0.1 mm layer hight. The print faild shortly after some small details startet, so even the 0.1 mm Prusament PLA setting isn't safe!
Postato : 04/02/2019 4:37 pm
Butterworth Design
I finally a good successful benchy to print at 0.15mm layer heights, using the same gcode that had failed multiple times before. In the time after my failed prints, here's what I've done/changed (in order) to get to this point:
  • Replaced the hotend PTFE tube. Another prusament print with different gcode failed again after this point.
  • Full and complete tear down/rebuild of the V6 hotend. Steps listed below.
  • Replaced original nozzle with fresh brass 0.4mm nozzle.
  • Added silicone heater block sock (new version)
  • Added DIY "thermal blanket" to the top side of the heater block, to block radiant heat from the top of the heater block to the bottom of the heatsink.
  • To rebuild the hotend, here's what I did:
  • Removed assembled hotend from extruder body.
  • While cold, loosened the heatsink from heatbreak
  • Heated to ~250°C, loosened nozzle
  • Cooled and disassembled everything.
  • Loosened and removed heater core and thermistor screws
  • Gently coaxed the thermistor and heater out of the heater block. By "gently", i mean I had to tap on some things with a hammer and punch, and thankfully didn't break anything.
  • Took a propane torch and burned all old filament off the heater block. Note: the temperature required for this will definitely oxidize the surface of the aluminum heater block! Rough aluminum oxide has a much higher emissivity coefficient than polished aluminum, and will likely cause issues with surrounding plastic and the heatsink getting too much heat radiated out to their surfaces.
  • Used the rough green scour side of a dish sponge and soapy water to burnish the aluminum oxide off, and get back to bare aluminum.
  • Used metal polish and a dremel/rotary tool to polish the heater block, the thermistor, and the heater core and remove any oxides and burned plastic from them and get back to smooth surfaces. This made assembly much smoother and easier than disassembly.
  • Meanwhile, the heatsink and heatbreak soaked in isopropyl alcohol. I had noticed a very fine layer of filament dust on the surface of the heatsink, and also wanted to remove old thermal paste.
  • Washed heatsink and heatbreak in soapy water, then dried well.
  • Reapplied thermal paste to top threads of heatbreak (Arctic MX4 here)
  • Installed my "thermal blanket" above the heater block, and reassembled the hotend using the steps recommended by Prusa and e3d.
  • The "thermal blanket" is a sandwich (from bottom-to-top) of Kapton (PEI) tape, a layer of woven fiberglass, and a layer of regular aluminum foil. The "thermal blanket" is a bit undersized relative to the top surface of the heater block. Sticky side of tape is attached to the fiber glass, aluminum foil is taped around the perimeter leaving as much of the shiny side of the aluminum foil exposed (shiny aluminum has low emissivity). I used a regular hole punch to cut the hole for the heatbreak, and installed with the non-adhesive kapton tape gently (not tight) against the heater block, and the exposed aluminum foil side facing the heatsink. A small amount of kapton was used to tape the blanket in place, but only enough to hold it (not a full wrap or anything like that).
    The "thermal blanket" and the silicone sock I think have really reduced heat transfer to the top half of the heatbreak and lower surfaces of the heatsink. That was the intent at least. So far, it seems to have worked, and I'm not suffering heat creep with Prusament at this time.
    Postato : 06/02/2019 10:32 pm
    Spacemarine
    (@spacemarine)
    This implies that heat-creep is the main factor in this problem?
    If so, why does heat-creep lead to a clog? And why is prusament with particles more affected than other PLAs? I don't think the thermal conductivity is that much higher.
    Postato : 07/02/2019 10:43 am
    Dave Jackson
    (@dave-jackson)
    I don't believe heat creep leads to a clogged nozzle, it allows the filament to swell in the PTFE liner and become jammed. The extruder then can't move the filament as its an interference fit within the PTFE liner. Prusament does seem to flow differently to standard Prusa PLA so there may be some change to the thermal conductivity.
    Postato : 07/02/2019 2:09 pm
    Butterworth Design
    heat creep... allows the filament to swell in the PTFE liner and become jammed
    This is correct, though I'd clarify that for my jams, the swelling was always immediately above the heat break, just below the PTFE tube. As the warm filament is pushed downward, it moves and creeps at a much higher rate - consider a ball or cylinder of silly putty: when you push down on the ball on a flat surface or between your hands, it's vertical length is reduced (it is compressed) while the diameter increases as the compressed material expands in the other directions.
    My nozzles were never clogged - in fact, when I removed the jammed filament and compared to a perfect cold-pull, it was easy to tell that the jammed filament was simply too wide to fit through the heat break any more (i measured between 1.9mm and 2.1mm with my calipers).
    Once the filament was no longer being pushed into the heatbreak, all of the melted filament ended up just draining out via gravity, and the heatbreak and nozzle were nearly empty when I disassembled everything (the 2.1mm blob on the end neither fit into the heatbreak, nor could be pulled through the PTFE tube).
    I agree with this - I printed a perfectly acceptable benchy with Prusa Silver PLA with the same gcode that failed with prusament. It also may not be thermal conductivity alone, but other additives and formulations of the PLA may slightly change properties like the glass transition point (Tg); a lower Tg PLA would be more susceptible to deformation at the same temperature.
    I'd also add that a jam above the PTFE tube would be related to heat probably from the extruder motor, and a jam below the PTFE tube (like mine) would be heat creep through the filament and heatbreak (and radiant heat to the heatsink) from the heater block itself. It's the same physical mechanism, but different root causes.
    Postato : 07/02/2019 6:18 pm
    Petri
    (@petri)
    I have exactly the same problem. Prusament Prusa Galaxy Black, ID 18687197. Printing at 0.15 mm layer height will start extruder clicking and serious under-extruding. Now that I discovered this thread, I'll try a couple of test prints with very low temperature settings and higher printing speeds to see if there is any positive effect.
    Postato : 21/03/2019 4:10 pm
    1 persone hanno apprezzato
    Petri
    (@petri)
    Test print running with https://www.thingiverse.com/download:2996134 that I had 100% failure rate around layers 20-25 with the default settings.
    Now the print is proceeding at ~ 2.5 centimeters without any underextrusion.
    My rationale for this test was that if the heat creep is caused just a small margin of settings difference, then the profile settings in Slic3r might help.
    Changes to print settings (0.15mm layer height, 20% infill, 2 perimeters):
    Print Settings
    -Speed
    --Modifiers
    ---first layer speed: 15 mm/s (not sure if this is overridden by the Min print speed set below)
    Filament Settings (Prusament PLA MMU2)
    -Filament
    --Temperature
    ---Extruder Other layers: 200 °C
    ---Bed Other layers: 50 °C
    -Cooling
    --Cooling thresholds
    --- Min print speed: 20 mm/s
    Setup: MK2.5S/MMU2/Hardened nozzle
    so it looks like lowering the print temperature by a handful of °C might do the trick
    Postato : 21/03/2019 5:50 pm
    Petri
    (@petri)
    No die, around 3 cm height the extruder clicking and underextrusion started again. Bummer. Tomorrow I'll still test other layers at 195
    Postato : 21/03/2019 6:08 pm
    Garrett B
    (@garrett-b-2)
    Chiming in to say that I'm seeing this exact same issue with mystic green. Jams up and clicks around the "window" section of a benchy along with sporadic under extrusion before it actually jams.
    Postato : 21/03/2019 11:04 pm
    Petri
    (@petri)
    195 degrees wasn't enough to melt the PLA properly -> Prusament Galaxy Black is unusable material for detailed printing at least with my setup
    Postato : 22/03/2019 9:02 am
    Petour
    (@petour)
    Have you realized that Prusament PLA settings uses 215 degrees temperature for all layers. I thing 195 degrees is too low for Prusament PLA.
    I have printed the Lion model with Prusament PLA Galaxy Black at 0.1 mm layer and several other models with Mystic Green, Galaxy Silver at 0.1 mm, 0.15 mm and 0.2 mm layer height without any failure. All models were sliced with the Slic3r PE 1.41.3 or 1.42 alpha with Prusament PLA filament profile.
    Postato : 22/03/2019 10:18 am
    Petri
    (@petri)
    Have you read this thread through? There is heat creep reported by several users.
    Postato : 22/03/2019 10:24 am
    Gritz
    (@gritz)
    Hi everyone, similar issue here.
    I tried to print D.Va's pistol with Prusament PLA pearl mouse and when the noozle reached 2 or 3 mm height it got clogged. Tried again and had the same issue at more or less the same height. Changed spool (same filament), same issue. Changed with the grey PLA that came within the printer, using the same .gcode file and everything went fine.
    Switched to my MK2.5 and had the same problem with another .gcode. So I wondered "What changes? Why the first mm are ok and then it gets clogged?" Maybe being close to the heatbed keeps the noozle temperature higher and when it moves the temperature drops. So I rised the temp to 220°C but it still got clogged.
    I really don't know what to do, despite the size of the print it stops extruding at 2 o 3 mm height.
    It happens only with Prusament PLA, with neon green PETG everything was fine.
    Postato : 23/03/2019 1:13 pm
    Petri
    (@petri)
  • I found one silicone sock and will try in a day or two how installing it alone impacts printing
    Postato : 23/03/2019 4:19 pm
    Matti Malo
    (@matti-malo)
    the nozzle in my printing has been never jammed but the jam has been in a tube, where diameter of the filament is growing. This morning I opened extruder and measured jammed filament, diameter was 2 - 2,1 mm. And this was in a top of the tube. (Pressure and heat may do this in a bottom ??)
    I believe, that the real reason for this is crystallization of PLA, dosn't matter, which color.
    - When the speed is high, there is newer problems.
    - When speed is low, (=more heat energy in extruder) problems can exist and if you repeat the print, the problem comes in same place, same height.
    Postato : 23/03/2019 6:49 pm
    Dewey79
    (@dewey79)
    Sounds interesting. I'l have to review this when I rebuild with the MK3S upgrade.
    Postato : 23/03/2019 6:58 pm
    GeorgeE
    (@georgee)
    Prusament pla and prusa pla have different temerature profiles so you shouldn't use the same gcode
    Postato : 23/03/2019 10:43 pm
    Mystic Brown seems prone to failure at low extruder volume. Either slow speeds or small layer heights. Increasing print temp to 230 has helped in some cases, but not all. Probably an effect of the copper/mica colored grains in it. Any filled material will present print issues.
    Postato : 23/03/2019 11:31 pm
    Pagina 1 / 3
