Is it possible to have infill only in on several bottom layers not a full height of vase like object?
Jaroslaw
(@jaroslaw)
Dear All
I need to print vase like objest with more than one  wall layers and nore than1 bottom layers. No top layers as this is inlet of vase like object. Whan I add infill I can only adjust shape and density of infill. My question is that: Is it possible to have infill only in on several bottom layers not a full height of vase like object?
Im using Prusa Slicer 2.5.0
 I would apprecieate any clues.
Best Answer by Neophyl:
Yes.  Use a Hight range modifier and specify the percentage of infill for that range.  Or use a modifier mesh to do the same thing in specific areas.
https://help.prusa3d.com/article/modifiers_1767
Please read through the knowledge base for the basics.  https://help.prusa3d.com/category/prusaslicer_204
This topic was modified 2 years temu by Jaroslaw
Opublikowany : 11/07/2024 12:34 pm
RE: Is it possible to have infill only in on several bottom layers not a full height of vase like object?
Opublikowany : 11/07/2024 5:23 pm
Jaroslaw
(@jaroslaw)
Wow thank you! Very elegant way.
I also resolved this by cutting model to 2 pieces is slicer and editing infill of one part in slicer editing box.
Thank you
Opublikowany : 12/07/2024 9:12 am
