Improving supported surface quality with PETG
I've been getting really good results using the default 0.2 Quality and default PET settings. My main issue now is that the surface quality of the supported surface is garbage, it's very stringy and generally terrible. It looks as bad or worse as the under-side of a long bridge.
What settings should I look at for improving it? Higher fan speed? Lower temp? Is this a lost cause?
Napsal : 19/02/2020 4:10 am
