i3 MK3 Stops Extruding - PLA Printing
Greetings from Canada!
I changed the extruder nozzle a few weeks back. All seemed to be going well. Until it didn't. A couple of prints didn't complete. The printer was "printing" but no filament was extruding. The extrude motor was turning okay. I unloaded the filament and loaded some new filament I sourced from a local supplier. I adjusted the tension on the bondtech drivegear thinking this might be the culprit but no luck. The alignment of the bondtech gears are good. All looks okay but my last two prints failed the same way.
What could be happening? Should I replace the bondtech drivegear?
Thanks,
robo67
Publié : 13/06/2020 12:53 am
