I keep having to change Z offset lower over time
3DPrints4me
(@3dprints4me)
So I got a fully assembled MK3S+ about 3 days ago,  printed great out of the box.  The Z offset from the factory worked perfectly on the smooth steel using PLA.  I got the Z axis configured for the satin steel and it worked great doing PETG.   I started noticing after around 5 prints or so I would have to lower the Z offset to maintain adhesion.  I have had to lower it 3 times so far roughly .1 mm or so at a time.  I am slicing using Prusa Slicer, mostly .2mm layer depth and no custom settings other than the filament type.
It prints great for a x number of prints and then I have to lower it to keep first layer adhesion.  I am cleaning the steel sheets with Ispopropyl alcohol between every print as recommended.  I don't have any acetone on hand to see if that helps.
Any ideas?  I am guessing there is some kind of Z sense drift going on?
My assumption is this is not normal.  Should I re-run the wizard?
Napsal : 07/11/2022 12:19 am
jsw
 jsw
(@jsw)
RE: I keep having to change Z offset lower over time
Is the Pinda firmly mounted in its holder?
Have you done a general inspection and tightening of any loose screws/bolts on the unit?
Napsal : 07/11/2022 1:15 am
1 lidem se líbí
Please show us a Z calibration print *on the print sheet*.
Napsal : 07/11/2022 2:18 am
It happens. Give the screw that holds the Pinda sensor in place a slight turn to make sure it's tight.
Napsal : 07/11/2022 11:31 am
