How to setup a colorchange at a specific layer AND let the printer cooldown.
Rams
 Rams
(@rams)
I own an MK3 without mmu.
I've succesfully printed a model with PLA and TPU in 1 print. That required a color change and adding a line of code for a temperature change. But there is a problem, when the printer asks for a color change, the nozzle/bed stays hot until you change the filament. This means that when I start a 3 hour print in the morningand  go to work, the printer is heated for like 10 hours.  So to minimize power usage I want the printer to cool down when changing color/material.
Either i need a color change + cooldown OR pauze at specific height and move the extruder away from the print.
I can add 1 line of code but this is beyond my current limit. How do it do this?
This topic was modified 6 years temu by Rams
Opublikowany : 30/11/2019 1:20 pm
Peter M
(@peter-m)
RE: How to setup a colorchange at a specific layer AND let the printer cooldown.
Bed needs to be heated because otherwise the model can  come loose.
Opublikowany : 30/11/2019 4:46 pm
Rams
 Rams
(@rams)
Posted by: @peter-m26
My prints do stick well enough when cooled down. But if this would not be the case, there would be a couple of ways to work around this. No problem for me.
This post was modified 6 years temu by Rams
Opublikowany : 30/11/2019 5:14 pm
