how to print top layer over perimeter
dukestah
(@dukestah-2)
Utenti
Is there any settings to change the way the top layer is printed? I'm looking for a way to cover the perimeter, to get a smooth and uninterrupted top layer. Now I have a lot of circles around holes and the whole edge is exposed at the top.
Thank you very much in advance.
Best Answer by bobstro:
You can use a modifier at the top to specify 0 perimeters and whatever infill you want. I posted a pic a while ago.
Postato : 07/03/2020 10:58 am
Peter M
(@peter-m)
RE: how to print top layer over perimeter
Printer settings - top fill pattern.
Search the web-forum google, there are settings you can use to change top layer.
Postato : 07/03/2020 11:08 am
Peter M
(@peter-m)
Print the last l few layers with 0.15.
Try slower,
try hotter.
try a bigger extrusion with on last few layers.9top solid infill).
Postato : 07/03/2020 11:18 am
RH_Dreambox
(@rh_dreambox)
If you change your model so that the top layer (and maybe the first layer>) covers the entire surface, the surface will be fine.
Then you just cut away any excess material that covers the holes.
Postato : 07/03/2020 4:55 pm
Postato : 07/03/2020 5:07 pm
dukestah
(@dukestah-2)
Utenti
Posted by: @bobstro
Wow, exactly what I'm looking for. My object has basically two top sections, one it's lower than the other and so I can place two height depending modifier.
Thank you very much!
Postato : 07/03/2020 5:57 pm
dukestah
(@dukestah-2)
Utenti
And to be fair, thanks to all who has commented 🙂
Postato : 07/03/2020 5:58 pm
have you considered using an interesting infill  such as Octogram Spiral, and reducing the extrusion multiplier to say .95 to prevent overlay / roughness
on the top layer
Postato : 07/03/2020 6:58 pm
1 persone hanno apprezzato
