How to print the bottom layer optically as even as possible with silk?
Hello,
I'm still trying to improve my aesthetic result with Silk Filament and mk3s+. Now I'm back at a point where I can't really get any further.
My goal is to print the bottom layer as even as possible optically. As seen in the photo, the appearance changes from the center to the edges.
Filament diameter: 1,72-1,78mm
I've tried:
Temperature: 215°-230°
Layers: 0.15mm
Extrusion factor: 0.9-1.1
Speed: 25-200mm/sec
Acceleration: 25-800mm/sec2
Retract: 0.8-2mm
Retract Speed: 35-50mm/sec
Retract length before cleaning: 0-50%
Linear Advance: M900 K0.05
Z Offset: 1.38-1.50mm (too close to high)
Velocity, Fan Speed, Volumetric Flow, Temperture is everywhere the same.
Can someone help me?
Thanks...
This topic was modified 2 years temu 2 times by Armin
Opublikowany : 15/03/2023 1:25 pm
