How to Fix/Remove Vertical Lines
Dewey79
(@dewey79)
Hello everyone and thank you for stopping in. I'm having problems with figuring out what is causing these vertical lines on the outside of the print and would like to get ride of them so my walls are cleaner.
When I brought it up inside another topic someone said they were related to the infill. If that's true how do you smooth them out to get rid of them. My prints have been coming out really well and even the first layer is great. This one blemish and it's a big one seems to be my biggest problem.
Any ideas on what I need to do to fix this? Firmware and Software versions listed below.
Fusion 360: 2.0.4116
Slic3r Prusa Edition: 1.39.1 windows 64 bit
MK3 Firmware: 3.1.3-245
Napsal : 06/05/2018 10:32 pm
thrawn86
(@thrawn86)
Re: How to Fix/Remove Vertical Lines
how to see what i'm looking at from that close, but what is the model you're using?
Napsal : 07/05/2018 7:56 am
Bytor
(@bytor)
How many perimeters and/or top/bottom layers do you have? You can try increasing the number of them. My experience is that some infill patterns show thru the perimeters/top/bottom layers if you only have 1-3 layers. Increasing the layers will reduce/remove them.
Also, try slowing down the infill speeds.
- 1st "printer" TIKO 3D
- 2nd PRUSA i3 MK2S with MMU v1
- 3rd PRUSA i3 MK2S
- 4th PRUSA i3 MK3 with MMU v2- 5th PRUSA i3 MK4 (upgraded from MK3) with MMU v3 (upgraded from…
Napsal : 10/05/2018 7:50 pm
