horizontal print separation
xt550
(@xt550)
Hello.
I have problem with horizontal separation , im trying to print a up side down "T" and when i apply some pressure to it sideways this happens:
h=ok V=nope
 it seams to be quite ok vertically
0,6mm nozle, noname PLA
Opublikowany : 13/04/2021 6:18 pm
Dan Rogers
(@dan-rogers)
RE: horizontal print separation
Under extruding.  Try hotter.
Opublikowany : 14/04/2021 1:27 am
Narrow parts stressed at 90 degrees to the lay of the filament are inherently weak, you only have the layer adhesion to overcome for a break.  @dan-rogers' suggestion should improve layer adhesion which will help but don't expect a great difference.
For strength you can either add buttresses if there is room or you can reorient the part.  If you rotate it 90 degrees so the first layer draws a 'T' on the plate the filament will be laid down continuously around the join and the part will be much stronger at that point.
Opublikowany : 14/04/2021 3:23 pm
xt550
(@xt550)
a tiny bit ABS in the extruder ,had to heat it up with a blowtorch
Opublikowany : 19/05/2021 1:39 pm
Dan Rogers
(@dan-rogers)
@xt550
Yikes ... i hope there is something left of the extruder body.
Opublikowany : 20/05/2021 8:16 am
