horizontal banding
my mini just recently starting horizontal banding. the only thing i have been able to do to correct it is reduce the print resolution. the only mod to my mini is the bondtech heat break. it has worked great so not a new change. i have dried the filament, squared the printer according to prusa article, done some cold pulls, checked belt tensions, changed filament ( both were prusament) nothing has helped. i have included pics of the test design below with .05, 1.0, 2.0 resolutions left to right 2.0 is only one that doesn’t exhibit the issue. i have also included the slicer files. the second picture is of a print at 1.0 resolution on the same machine before this started. any help would be appreciated. almost everything i print is at 1.0 resolution
RE: horizontal banding
sorry wrong forum i’ll move it
