Help , prusa m3
Roman Dembitskyy
(@roman-dembitskyy)
Help , prusa m3
Veröffentlicht : 06/09/2022 4:50 pm
Roman Dembitskyy
(@roman-dembitskyy)
RE: Help , prusa m3
Posted by: @roman-dembitskyy
I'm new to 3D printing, when printing 2 layers it begins to fray and tear. and then the part breaks off. help determine what the problem is. nozzle 0.4, temperature 260/85, print with petg filament,
Veröffentlicht : 06/09/2022 4:51 pm
RandyM9
(@randym9)
RE: Help , prusa m3
Looks like wet filament.
Z height could also be too low but impossible to say for sure until filament is dried.
Dry the filament and then do a first layer calibration print and post a pic of it ‘on the bed’ back here so folks can evaluate from there.
Cheers
Veröffentlicht : 07/09/2022 4:17 am
Robin
(@robin)
RE: Help , prusa m3
What kind of printer do you have, the pics do not look like an original Prusa MK3(S+). Did you build it yourself? Did it ever print successfully?
Did you do the preflight check: https://help.prusa3d.com/guide/9-preflight-check_76792 and the recommended calibrations?
As Randy wrote. Post the rectangle from your last first layer calibration. Also: Start with fresh, quality PLA filament. It's most forgiving, if you got that to work, try PETG or whatever you like...
Veröffentlicht : 07/09/2022 11:43 am
