Help needed for Prusaslicer Settings...
Basic
(@basic)
I want to print a sorta compliant spring mechanism with the most delicate wall thickness possible, so I chose a thickness of 0,4mm..:
the issue
from above, sliced it looks like this (its supposed to be made in PA):
Sliced
though, from here I run into problems!
Which settings will I have to choose -- or, what to do, if I wanna have a continuous extrution of filament around each loop of hole?
design
thanks a million!
Dieses Thema wurde geändert Vor 3 years von Basic
Veröffentlicht : 24/10/2023 8:37 pm
Basic
(@basic)
RE: Help needed for Prusaslicer Settings...
I changed the minimum wall thickness to 0,5mm now..:
but I still get unwanted "interconnections" - which I rather choose to change some shift somewhere away from the most critical region of the spring.
Any suggestions?
thx
Veröffentlicht : 24/10/2023 8:45 pm
By the look of it your wall thickness in some of the curves fell below a single extrusion width.  Where parallel curves are laid out with cartesian spacing the distances can vary in hard-to-calculate ways.  If you want a single extrusion then your best chance is to set the cartesian spacing at just under two extrusion widths, say, 0.8mmn and disable arachne.
Veröffentlicht : 24/10/2023 11:13 pm
