Help improve my print quality
dumaresq
(@dumaresq)
I got my printer (mk3) built a few weeks back and I’ve been printing lots of stuff :).
I am a little disheartened by the way some objects come out. Can someone suggest what’s wrong? I believe I’ve got my belts tight enough. But the print maybe has layer shift?
Veröffentlicht : 25/01/2019 2:18 pm
timo.m
(@timo-m)
Re: Help improve my print quality
Do you have these artifacts both in X and Y direction?
For a start you can check if the grub screws against the drive shaft on the idlers are tight. Looseness of those might lead to what looks like tiny layer shifts.
Veröffentlicht : 25/01/2019 5:21 pm
Nikolai
(@nikolai)
Looks like the root cause is uneven extrusion. Here are my thoughts on it:
1. Check extruder gears are perfectly aligned and sits tight
2. Change filament.
3. Make some cold pulls to clean up the nozzle
Often linked posts:
Going small with MMU2
Real Multi Material
My prints on Instagram
Veröffentlicht : 25/01/2019 6:32 pm
dumaresq
(@dumaresq)
I don't think it's the the grub screws those seem fine (I checked them recently with the belt tension). it could be uneven extrusion though, the gears look fine, and I believe I've got the right tension on the extrusion gears (though it isn't clear to me how to check) I very likely could need to do some cold pulls I've had clogs in the past....
Veröffentlicht : 26/01/2019 12:42 am
dumaresq
(@dumaresq)
Did a few cold pulls and printed it again. The results are much better!!!
Is anything wrong with this (seems near perfect to me)? Anything else I should do?
Thanks so much!
Veröffentlicht : 26/01/2019 12:08 pm
Nikolai
(@nikolai)
Glad it did work out. Without knowing how you sliced it, maybe reduce the extrusion multiplier and slow down the print. It might produce better quality.
But with a pure white filament I would consider this as a really good print already.
Often linked posts:
Real Multi Material
Veröffentlicht : 26/01/2019 7:40 pm
