HELP
alvaroachu
(@alvaroachu)
HELP
I tried to print this figure with 200ºC and heating the heated bed to 60ºC temperature.
And the ornaments peeled off causing it not to print well.
The material to be used is PLA and the manufacturer recommends heating its filament from 200ºC to 220ºC, but I heat it to 200ºC because with some figures hardly any threads come out due to retractions.
I have printed this figure at 65ºC bed temperature and after using glue stick it sticks very well and prints very well without problems.
I attach the files in case someone can help me.
Bola FelizNavidad
Publié : 02/12/2024 10:24 am
Robin
(@robin)
RE: HELP
The STL is no help, we need your ZIPed .3mf project file from Slicer (it contains all settings in addition to the model).
Since you posted this in the MK3 help section I believe this is the printer you have? If so, which PEI sheet (take a picture if you are not sure).
If you don't mind: redo the build in first layer calibration and take a picture of the resulting rectangle still on the print sheet and post that (decent lighting and in focus helps a lot).
Publié : 02/12/2024 11:21 am
