Half of the first layer is spreading out to much
Itworks Co
(@itworks-co)
Napsal : 12/12/2022 9:07 pm
Itworks Co
(@itworks-co)
RE: Half of the first layer is spreading out to much
Looking at the first photo (Front) you can see his head had a lot of gaps between the lines
Looking at the second photo (Back) you are able to see that the lines go a little further down to his upper back but is no longer an issue once you get to the chest.
What setting do I need to change to get this more consistent?
Napsal : 12/12/2022 9:12 pm
RandyM9
(@randym9)
Your live Z needs to be adjusted closer to the print bed, or a larger negative number as you adjust it.
See this thread for a test print and instructions:
Cheers
Napsal : 13/12/2022 4:58 am
